Val3New Contributor3 years agoQuartus 21.1 crashes every ~5 minutes while working with Signal Tap Problem Details Error: *** Fatal Error: Access Violation at 00007FFDA5AA6840 Module: quartus.exe Stack Trace: 0x20683f: QQuickYAnimatorJob::`vftable' + 0x1b3f (Qt5Quick) 0x20c6ad: ...Show More
SyafieqSSuper Contributor3 years agoHi Valeriy,Is it possible for you to attach the design or small design that replicate the issue? I will reproduce and work on it.
Recent DiscussionsDuplicate_hierarchy_depth / duplicate_registerTiming analysis - long combinational pathAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SGQuartusPro 25.3 Crashed after using the Signal Tap Logic Analyzer
