9 years agoQuartus 13 jpg image export not working correctly ?
When I click on export from the file menu to export a JPEG image, it seems to totally miss off the top half of the image and I cannot figure out why.. It looks like the image size is correct...
9 years ago --- Quote Start --- Hi, I try to load your bdf, it is indeed export problem. One workaround you can do is cntl + A, move your entire logic down a bit by pressing down. You should be able to export it. Thanks, Best regards, Kentan (This message was posted on behalf of Intel Corporation) --- Quote End --- Moving it down solves the problem as you suggested, many thanks. The workaround I was using was to export using a print to image driver. This seemed to export okay other than a large blank gap at the bottom of the image.
