12 years agoThank you for describing your fix to the problem you were having. I have the same problem, and presume that the same remedy will solve it for me as well. One followup question: You said that you moved the Altera directory to the disk's root directory (to avoid the space in the path name that included "program files"). My question is whether you had to do an uninstall followed by a reinstall of Quartus 13 in the new location, or whether you can just drag the directory to the new location.
