11 years agoQsys SPI(3 Wire Serial) control
Hey, I am trying to build a SPI interface using the Qsys tool for a Cyclone IV I am using but I can't seem to figure out how to use the SPI (3 Wire Serial) IP in the catalog. It requires an Avalon M...
10 years ago --- Quote Start --- Have a thorough read through the datasheet for the 'spi core' (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/n2cpu_nii51011.pdf). This covers all aspects of the peripheral, what it should connect to, and how to control it. You can also refer to the spi slave to avalon master bridge design example (https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-spi-bridge.html) on Altera's website. This does everything you require. Cheers, Alex --- Quote End --- Alex, I looked at the SPI slave to avalon master bridge design example, it looks like in Quartus 16.0 this example is demo for internal loopback? If I want to use it as SPI master, I guess I have to link each pin using pin/chip planner to external interface? Benson
