13 years agoSorry I should have re-read my answer... I meant only if the parameter is not 0. When 0 it basically means there is no pipelining and the read data valid signal isn't needed. Try to set it to another value (ideally to the highest number of transactions you plan to have before getting a read value back) and see if the signal becomes valid.
