13 years ago --- Quote Start --- Did you declare that the avalon master would use pipelining? It is possible that QSys would only generate the logic behind the read data valid signal when the "Maximum pending read transactions" parameter is 0. --- Quote End --- The "Maximum pending read transactions" parameter is set at 0 currently.
