12 years agoWoooh !
1) I think you can't make a process inside a process 2) rename the loop variable 'j' and 't' OR rename/delete your SIGNALS 'j' and 't' : to avoid confusion 3) Could you post your schema ? I bet you need a synchronous design, if so, employ
process(clk) -- or process(reset_n, clk) if you had a reset_n
if rising_edge (clk) then
q<=(q(2)xor q(3)) &q(0)&q(1)&q(2);
k<=q;
-- something like that : nested loops
-- you must build finite loops because the FPGA have a finite number of logic elements AND synthesizer wouldn't want infinite structure.
for j in 0 to 3 loop
for t in 0 to 3 loop
if (k(t) /= d(t+(4*(j-1)))) then
count := count+1;
end if;
end loop;
end loop;
end if;
end process;
-- It could be written easier, maybe.
