17 years agoWell I REALLY want to thank you for this answer!
I had no idea the speed grade also influences maximal IO speeds. Unfortunately, the -6 grades are only available on BGA packages, which we cannot solder ourselves on prototyping boards. But at least now we know what is the limiting factor. Your suggestions on operating the bank at 2.5V and leaving the VCC for the rom at 3.3V is also most useful. I'll make the bank IO voltage selectable in case things go wrong after all. Thanks again!
