14 years agoProblems downloading ELF
I downloaded the Quartus II last version and the service pack (legacy) to design hardware for a FPGA (Cyclone II EP2C20F484C6N) and I selected this device when I was creating the project in Quartus II. I have problems to download the ELF file from the NIOS II with a Hello World. The error only says that "Downloading ELF Process failed", that's all. I saw several times the time-limited OpenCore version advertisement in warnings and I am not sure if this is not working because of that. Furthermore, it is doing the synthesis without EDA Netlist Writer (if I select in Settings->EDA Tool Settings->Modelsim VHDL, it says "can't generate netlist output files because the license for encrypted file "path/cpu_0.vhd" is not available"). I don't know how to fix this :( Does anyone have any suggestion? Thank you in advance.
