16 years agoProblem wuth altsyncram
Hi, I included in a top level schematic design an altsyncram function. I configured the altsyncram with MegaWizard as a true dual port ram (both rd and wr on each port), 8 bit wide and 4096 deep...
9 years agoHi Cris,
By definition, a Dual Port RAM has Port A and Port B. Thus it will also have two Clocks ( clockA and clockB ). It looks like you have not connected the clock for Port A in your design. Please check and connect the clock port for Port A to the same clk_50m signal. Make sure you're instance has the correct port definitions. Thanks Abr
