15 years agoIf your system (including the CPU) is clocked at 100MHz and your SDRAM is at 133MHz are you sure you are not hindering your performance? For a 33MHz speed increase is it worth the extra 9-12 clock cycles for the clock crossing that you have inserted? So before trying to tune this memory interface I recommend asking yourself "do I really need my RAM operating this fast???"..... just a thought. The first two chapters go into more detail: http://www.altera.com/literature/hb/nios2/edh_ed5v1_03.pdf
