15 years agothere is some info on constraining SOPC systems if you search on this blog. I can tell you that the clock phase shift is all that is necessary though.
Have you done a timing analysis? Are you passing timing with the SDRAM controller running at 133? I could barley get mine to run at 100Mhz on a CIII spd grade 8. Have you tried running all are you using a custom SDRAM controller or one that is preconfigured in SOPC builder?
