16 years ago --- Quote Start --- ModelSim or Quartus Simulator? --- Quote End --- It is ActiveHDL 7.2. But, I do nor remeber if I had any problems with either Xilinx or functional simulation. if I define the small range counter
CNT: buffer integer range 0 to 1 the post-fit will not even compile because of # Compile Error: Explicit type conversions are allowed between closely related types only.at line CNT <= IEEE.STD_LOGIC_ARITH.CONV_INTEGER(SIGNED(ww_CNT));Range 0..2, CNT: buffer integer range 0 to 2compiles but crushes in simulation RUNTIME Fatal Error: Value -2 out of range (0 to 2). on the same line. Even the initial value CNT: buffer integer range 0 to 2:= 0does not change the things. Where the negatives comes from? Either I do not understand something or there are more problems with Altera fitter than those related to delta delay. The RTL and post-synth still run somoothly. --- Quote Start --- setting CLK and other input signals simultaneously doesn't create a valid timing --- Quote End --- Where do you see them changed simultaneously?
