16 years agoHere is an example. The synthesized counter first
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity BIST is
port (
clk, start: std_logic;
CNT: buffer integer range 0 to 1000
end BIST;
architecture RTL of BIST is
begin
FF: process (CLK)
begin
if Rising_Edge(Clk) then
if CNT = 1000 then
CNT <= 0;
else
CNT <= CNT+1;
end if;
if START='1' then
CNT <= 0;
end if;
end if;
end process;
end RTL;
and the verification test bench:
library IEEE, POST_SYNth_CUT;
entity VERIF_TB is
end VERIF_TB ;
architecture BEH of VERIF_TB is
signal CLK: std_logic;
constant PERIOD: TIME := 10 ns;
signal START: std_logic;
begin
FUNC: entity WORK.BIST
port map(
CLK => CLK,
START => START,
CNT => open
PS: entity post_synth_CUT.BIST
port map(
CLK => CLK,
START => START,
CNT => open
CLOCK : process
begin
CLK <= '0'; wait for 85*PERIOD/100;
CLK <= '1'; wait for 15*PERIOD/100;
end process;
START_PROC: process
begin
START <= '0';
for cycle_cnt in 0 to 20 loop
wait until CLK = '1';
end loop;
-- wait for 1 fs; -- add a delta dealy
START <= '1'; -- pulse start
START <= '0';
wait;
end process;
end BEH;
On the 21th count (clock period), the start is made high. On the next clock, count is zero, therefore. But, it is not in the post-fit simulation. The post-fit becomes 20->0 instead of taking value 21 as expected and as RTL and post-synthesis do. It seems that post-fit process, on clock edge, takes the start <= '1' that is raised after clock. It does not appear correct. If TB delays the start by a moment then both counters are synchronous. Is it because I use "9.1 Build 222 10/21/2009 SJ Web Edition" or Stratix II EP2S15F484C3? Simulator goes crazy?
