11 years ago
OpenCL Initialization Error, Ver. 14.0.1.205
I have no problems building and running the vector addition example using Ver. 14.0 of the Altera OpenCL SDK (I'm running the Bittware s5phq). However, after installing the recent update (Ver. 14.0.1.205), I can still build the .aocx file with no errors:
Microsoft Windows [Version 6.1.7601]
>vcvars64.bat
>aoc -v -c vectorAdd.cl
aoc: Environment checks are completed successfully.
aoc: Selected target board s5phq_d5
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Compiling....
aoc: Linking with IP library ...
aoc: First stage compilation completed successfully.
aoc: To compile this project, run "aoc vectorAdd.aoco"
>aoc -v vectorAdd.aoco -o vectorAdd_20140904.aocx
aoc: Setting up project for CvP revision flow....
aoc: Hardware generation completed successfully.
But now I have new problems when attempting to run the example:
Initializing OpenCL
Platform: Altera SDK for OpenCL
Using 1 device(s)
s5phq_d5 : S5PHQ
Using AOCX: vectorAdd.aocx
MMD INFO : [acl0] New FPGA design has different periphery from programmed design.
MMD INFO : AOCX base and CvP periphery hashes differ. Programming will fail in hardware, so aborting.
MMD INFO : executing "quartus_pgm -c 1 -m jtag -o "P;reprogram_temp.sof@1""
'quartus_pgm' is not recognized as an internal or external command,
operable program or batch file.
MMD INFO : Link currently operating at 5 GT/s.
MMD INFO : Link operating at Gen 2 with 8 lanes.
MMD INFO : Expected peak bandwidth = 4000 MB/s
mmd program_device: Board reprogram failed
MMD FATAL: acl_pcie.cpp:59: can't find handle -1 -- aborting
What is all of this about? Anyone else have issues like this with the latest update installed?
Thanks!
    --- Quote Start ---
    Did you re-flash the board with an updated image?
    --- Quote End ---
    Hi Rudy, that's a great observation. I was under the impression that the latest Bittware top.rbf files were generated under 14.0 (not 14.0.1, but maybe I'm wrong on that). Anyway, now that I have a new top.rb file generated from the Vector Addition example using Ver. 14.0.1, I'll load that version, at least that is what I suspect might work based on your feedback. I'll let you know how it turns out.
    Thanks again!
    --- Quote Start ---
    Thanks again!
    --- Quote End ---
    Rudy - that did it! Thanks for catching my error.
