16 years ago --- Quote Start --- Thanks, that turned out to be my problem in the end. I was unaware that you needed to set it as the top level entity. As in regards to the earlier post, what do you mean by post my project. Is there a way to post files in these forums? The actual project is to design a stopwatch that outputs to a seven segment display that will output to an fpga board, using dff's to form a register, the adder circuit, a frequency divider, and several other parts. I dont know if that would be too large. As of now i'm almost done however when i compile i keep getting two warnings, Firstly that "Warning: Output pins are stuck at VCC or GND", and also that "Warning: Design contains 3 input pin(s) that do not drive logic". Then when i try to simulate my design those outputs are non responsive. Are there any general causes for these warnings i could look at or are they fairly specific. --- Quote End --- Hi, there are two ways to post your project. You can generate an project archive with quartus or you can put all your stuff in a zip-file. Under the window for your post you find Additional Options. Press "Manage Attachments" and upload your archive or zip-file. Kinf regards GPK
