11 years ago --- Quote Start --- When choosing the device (under 'Assignments' -> 'Device...') that particular device is labelled '(Advanced)'. So, it will not generate a .sof when compiling :cry: As for the 'trace' I referred to - messages appear in the 'Processing' tab (in Quartus) as it's compiling. I thought (for the 'Advanced' devices) it told you it wasn't going to generate a sof. However, having just tried it with 13.0sp1 web edition and your device, it doesn't. So, I suggest you update your software. Version 13.1 and newer support that device. Cheers, Alex --- Quote End --- Thanks Alex. I also tried installing Q13.1 version (web edition) but it asks me for 30 day evaluation which is unlike the other Quartus version which are feature limited not time limited. Isn't their any web edition for Q13.1 which is not time limited?? PFA for the message window from Quartus 13.1. Any suggestion on this issue.
