11 years ago --- Quote Start --- Assuming compilation does complete successfully there should be a reference to the sof generation in the compilation trace. I appreciate the device you're using should be included in the version of Quartus you're using but typically, if you aren't licensed for a particular family, the trace will explicitly state it's skipping sof generation. Can you specify exactly which device you're using? Is the Quartus build 232? Cheers, Alex --- Quote End --- I am using DE1-SoC board (cyclone 5cSEMA5F31C6) and yes it is build 232. I have this device selected as the target device for my project. So if I can get an option to select it as target device I assume this ver of quartus should support this device. I am using web edition, but I am getting .sof for cycloneII devices. Whats actually compilation trace? Where can I see that? And how can I found whether I have support for this particular device family or not? Thanks
