11 years agoAssuming compilation does complete successfully there should be a reference to the sof generation in the compilation trace. I appreciate the device you're using should be included in the version of Quartus you're using but typically, if you aren't licensed for a particular family, the trace will explicitly state it's skipping sof generation.
Can you specify exactly which device you're using? Is the Quartus build 232? Cheers, Alex
