Jaganathan
4 years agoNo output while simulation using Waveform Editor
I tried simple circuit using not gate as per below
and I simulated using waveform editor, but there is no output in simulation. Refer below image,
My Quartus Edition: Quartus Prime ...
StefanoMarsi
4 years agoI have the same problem too:
No output signal comes using "Run Functional/timing Simulation" inside Simulation Waveform Editor.
I tried different simulators (Modelsim/Questa) but even if the process terminates successfully without any error, no output is displayed.
StefanoMarsi
4 years agoOK I Found the solution by myself:
1- Instead of removing the "-novopt" from the simulation options try add it with : -suppress 12110
(e.g: vsim -suppress 12110 -novopt $ elabcommand )
2- Control that in the folder "C:\intelFPGA_lite\21.1\questa_fse\intel\verilog\cyclonev" (depending from your device) you have a complete write access.
