Jaganathan
4 years agoNo output while simulation using Waveform Editor
I tried simple circuit using not gate as per below
and I simulated using waveform editor, but there is no output in simulation. Refer below image,
My Quartus Edition: Quartus Prime ...
RichardT_altera
4 years agoI able to output in the simulation though. With the Modelsim Intel edition set as the EDA Tool Options in Quartus.
I not sure why you place the waveform4.vwf in the /output_files directory, it made the Quartus cant find the vwf.vt files needed to run simulation.
Anyhow, I move the files to the same folder with .qpf project files. Open the Waveform editor > Simulation > simulation setting. Click Restore Default and remove the -novopt from the script.
Save and run functional simulation. Everything runs successfully and the F node output the waveform correctly.
