9 years agoNeed help capturing the period of a wave form. (Verilog)
My code requires that I store the value of an input signal's period in a register. I have mocked up the code below to register the period, but I cant yet confirm that it works. In your experience do ...
9 years agoI see several things wrong with it.
1) Like sstrell said, "posedge" is spelled wrong. 2) There is no initial values or reset for the pos_length and neg_length registers. While the FPGA will initialize with these zero the simulation will have the values of "x" and "x" plus 1 remains "x". 3) same issues with pos_cntstop and neg_cntstop 3) the sequencing of the high period count and low period count is just not right. Assume that at time 0 in_signal is high, which will allow pos_length to start counting. Also assume pos_cntstop is negated. Because in_signal is not low neg_cntstop will be asserted. As soon as the in_signal goes low, pos_cntstop will be asserted. On the next clock edge neg_length will begin counting, but neg_cntstop is already asserted from the previous high period. Because pos_cntstop and neg_cntstop are both asserted you will clear both the counts and the "stop" bits. Your register total_T will only show half the clock period. 4) There is also a major problem if in_signal is not synchronous to sys_clk. An asynchronous signal applied to the enable of counter is guaranteed to fail. You would be better off to have a single period counter and count the time between rising edges of in_signal. First, double register "in_signal" to get it into sys_clk domain. Then have one more register: in_signal_sync_dly. The riding edge can be detected from In_signal_sync & !in_signal_sync_dly. So, it becomes:always @(posesge sys_clk)begin
in_signal_sync0 <= in_signal;
in_signal_sync <= in_signal_sync0;
in_signal_sync_dly <= in_signal_sync;
if (reset) begin
total_T <= 32'h0;
legnth_count <= 32'h0;
end // of reset
else begin
if (in_signal_sync && !in_signal_sync_dly) begin
total_T <= legnth_count;
end
else begin
legnth_count <= legnth_count + 32'h1;
end
end // of not reset
end // of always
