KN8
4 years agoNeed Component Editor to change its parameters (eg reduce port sizes & add new ports)
Quartus Prime Standard Edition we have at ASML doesn't look to have QSYS Platform Designer 'Component Editor' Drop Down button We require this 'Component Editor' so that we can : Change the par...
sstrell
4 years agoYou can't make design-level changes to off-the-shelf IP. You can only customize the IP's parameters. That's kind of the point of it being IP.
If it's not an encrypted/licensed IP, you can use its design as a base for your own custom IP.
As for the design itself, if there are signals or ports you don't use, you can just leave them unconnected or pulled high or low as needed.
