KN8
4 years agoNeed Component Editor to change its parameters (eg reduce port sizes & add new ports)
Quartus Prime Standard Edition we have at ASML doesn't look to have QSYS Platform Designer 'Component Editor' Drop Down button We require this 'Component Editor' so that we can : Change the par...
sstrell
4 years agoI'm not sure I understand what you mean. Are you saying the Component Editor simply doesn't exist in your installation? You can't double-click "New Component" in the IP Catalog in Platform Designer?
Or are you saying you are trying to open the Component Editor for an off-the-shelf IP? You can't use the Component Editor for off-the-shelf IP, only for your own custom components. You edit parameters when you add an off-the-shelf IP to your system to change how it works.
