10 years agoMoore Finite State Machine questions (VHDL and C)
Hello, I am having some troubles with my Moore state machine. Is it actually possible to use an internal signal or variable dependancy in a IF-statement during a process? Im using a the next...
10 years agoIm not quite sure what you want. Your first post implies that you assume the process is executed over some finite time. It's not. Its executed in 0 time. Your state transition occurs on a clock edge, so if the RESETSTATE has a next state assignment to state_B, then it will happen on the next clock edge.
