fpgamodelsim
4 years agoModelSim not found in executable Quartus 2
I know that I had two issues that were relevant to VHDL. I know that one of them is that when I compiled the Quartus 2 program, I found out that ModelSim was not found in the executable for ...
RichardT_altera
4 years agoRegarding the executable issue, have you set up your EDA Tool Settings in the Quartus software?
https://www.intel.com/content/www/us/en/docs/programmable/683248/18-0/specify-eda-tool-settings.html
Next, I recommend that you go through the tutorial that is available in the Quartus Simulation Waveform Editor > Help> Simulation Tutorials > PDF Tutorial for Verilog/VHDL users. To get an understanding on how the simulation flow works and compare it to your project to check where goes wrong.
You may find it in the Quartus installation directory.
<quartus installation path>\quartus\common\help\tutorial_quartusii_simulation_verilog.pdf
