10 years agoMODELSIM Demultiplexer simulation fails. Hidden Altera internal modules(?)
Hello all, I am trying to simulate the Avalon ST Demultiplexer (and corresponding multiplexer) in ModelSim but only get zeros as output signals. My problem is that signals go in, but I h...
10 years agoI believe I have found an answer for all those who might search for it: It is simply not provided for by Altera.
Chapter 18 of the UG-01085 Embedded Peripherals IP User Guide (2016) says the following: --- Quote Start --- Hardware Simulation Considerations The multiplexer and demultiplexer components do not provide a simulation testbench for simulating a stand-alone instance of the component. However, you can use the standard SOPC Builder simulation flow to simulate the component design files inside an SOPC Builder system. --- Quote End --- It is thus not possible to simulate an isolated extraction of either the multiplexer or demultiplexer components.
