ZKhan1
4 years agoModelsim-Altera do file paths
HI ,
I have a design in which i have placed all ip that i have used in separate folders like for pll i have put the generated files in altera_pll , for dpram in altera_dpram .
I can compile the ...
RichardT_altera
4 years agoMy guess is that modelsim is not directed to the correct file directory.
Check your .do file and see if it is correct. Since you have a success simulation case, you should be able to compare between the .do file and see where goes wrong.
