ZKhan1
4 years agoModelsim-Altera do file paths
HI ,
I have a design in which i have placed all ip that i have used in separate folders like for pll i have put the generated files in altera_pll , for dpram in altera_dpram .
I can compile the ...
RichardT_altera
4 years agoAfter you move the files, have you tell Quartus to compile the project again with the new files directory?
Nativelink is an automated simulation flow to generate simulation scripts, compile simulation libraries, and auto launch your simulator following design compilation.
So, it is normal to see that your .do file has been written over every time you run Nativelink.
