ZKhan1
4 years agoModelsim-Altera do file paths
HI ,
I have a design in which i have placed all ip that i have used in separate folders like for pll i have put the generated files in altera_pll , for dpram in altera_dpram .
I can compile the ...
RichardT_altera
4 years agoAs shown in the error message, the library "lib_top_pas_rs_hssl_mk2_fw" is not found.
I see that you are using quartus lite, could you try to run the Nativelink Simulation ?
