12 years ago
Missing LIbrary for ModelSim in Quartus II Version 13.0 SP1
I am using Quartus II Web Edition 13.0 SP1 (the last version to support the EPM7128S I believe)
The device exists in Quartus II and I have been able to build a schematic.
When I try to run a simulation, ModelSim generates errros such as
# Top level modules:
# First
# Model Technology ModelSim ALTERA vlog 10.1d Compiler 2012.11 Nov 2 2012
# -- Compiling module First_vlg_sample_tst
# -- Compiling module First_vlg_check_tst
# -- Compiling module First_vlg_vec_tst
# First_vlg_vec_tst
# vsim -L max7000s_ver -L altera_ver -L altera_mf_ver -L 220model_ver -L sgate -c -t 1ps -novopt work.First_vlg_vec_tst
# Loading work.First_vlg_vec_tst
# ** Error: (vsim-19) Failed to access library 'max7000s_ver' at "max7000s_ver".
# No such file or directory. (errno = ENOENT)
When I look in the verilog directory below \modelsim_ase_\altera I can see max, maxii and maxiv directories, but not a specific max7000s one.
Can anyone help me find/fix the problem please?
regards
Dave
    I know Quartus has dropped support for the MAX7000. THey probably removed the libraries from modelsim also.
    thanks for the reply, but I don't think that is the problem. Yes, the MAX7000 has been removed from 13.1, but it is still present in 13.0SP1.
    If I launch the Simulation Library Compiler, I see the MAX7000 in the list of Available Families, and the MAX7000S in the Selected Families box.
    There is also a text string advising "Note: ModelSim-Altera software comes packaged with precompiled simulation libraries.
    So, it would appear that both Quartus II and ModelSim are aware of the 7000S, but that the library is not actually present?
    regards
    Dave
    OK, after a bit more digging around, I find that the Help file for Version 13.0 lists
    "ModelSim-Altera Precompiled Libraries
    max MAX 3000 and MAX 7000
    maxii MAX II
    maxv MAX V
    Suggesting to me that the max library should be used for the MAX7000
    When I look in modelsim.ini, I see
    Under VHDL
    "max = $MODEL_TECH/../altera/vhdl/max
    maxii = $MODEL_TECH/../altera/vhdl/maxii
    maxv = $MODEL_TECH/../altera/vhdl/maxv"
    Under Verilog
    "max_ver = $MODEL_TECH/../altera/verilog/max
    maxii_ver = $MODEL_TECH/../altera/verilog/maxii
    maxv_ver = $MODEL_TECH/../altera/verilog/maxv"
    i.e., no entry for MAX7000S
    If I manual create entries
    "max7000s = $MODEL_TECH/../altera/vhdl/max
    max7000s_ver = $MODEL_TECH/../altera/verilog/max"
    i.e., pointing to the max directory as suggested by the help file, the simulation seems to be created OK.
    SO : FOLLOW UP QUESTIONS
    1. Is what I have done valid, i.e., will not lead to incorrect simulation results?
    2. Does this suggest an error in the setup for V13.1SP1, or
    3. Have I done something else to break the association between MAX7000S and the max library?
    regards
    Dave
    if max7000 needs library max then what you done is correct mapping
    it seems that mapping was not done in your setup
    Thanks for the reply, it seems like I have stumbled across a solution then!
    Dave
