CasperChen
4 years agoMissed to generate ModelSim FEATURE in my license file
Recently, my license file was expired. So, I went to re-generate my license file again. However, I found it generate the empty ModelSim FEATURE as follows in my license file:
# FEATURE ST...
- 4 years ago
Right now, I can run ModelSim with the above new license file LR-083849.
I found that ModelSim needs the license file name used with MGLS_LICENSE_FILE/LM_LICENSE_FILE is as same as that used in "Quartus --> Tools --> license setup...".
Basically, the new license file generated with all features can fix the root cause.
AR_A_Intel
4 years agoThanks for your update, hope all is well. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
