11 years agoMegaWizard Plug-In Manager hangs when making a PLL (Quartus II v14.1.1)
The following problem is completely repeatable: Within Quartus, in IP Catalog window (default position on right of screen)select: Installed IP -> Library -> Basic Functions -> Clocks; PLLs and ...
11 years agoUbuntu Os is not supported in Quartus II 15.0, which is why you might see unexpected behavior. Try to use the supported OS
