11 years agoMegaWizard Plug-In Manager hangs when making a PLL (Quartus II v14.1.1)
The following problem is completely repeatable: Within Quartus, in IP Catalog window (default position on right of screen)select: Installed IP -> Library -> Basic Functions -> Clocks; PLLs and ...
11 years agoSee this post for a workaround
http://www.alteraforum.com/forum/showthread.php?t=47420&p=199388#post199388 --- Quote Start --- Pete, Funny you should mention it... I attended one of the max10 workshops a couple weeks ago and kept running into that. It is a GUI bug. Right after you open the dialog, stretch the window out a little (drag a corner) and make it so scrolling is not necessary. For me, once I adopted that "use pattern", I avoided the crash. It slowed me down in the workshop something crazy though because of the way it would just hang. --- Quote End --- This workaround appears to resolve the issue also on my 15.0 installation, running on Ubuntu 14.04 LTS.
