LogicLock Arria10 issues with Platform Designer projects
Hi Richard!
I'm using the Standard version!
Do you have any information when there will be a solution?
It seems that the Signal Tap Logic Analyzer has the same issue!
I am working with Quartus 18.1 Standard because this is the last version which does not need Windows Subsystems for the NIOS generation.
I really need a solution for that issue!
BR
Erich
Hi @EGrub
Here's the feedback I get from the engineering team:
Here are some things to try:
1. "*|*:calibration|*:adc"
We should try adding another (or more) leading wildcard: *| , as wildcards sometimes do not cross hierarchical boundaries.
2. Is adc is a hierarchy or bus? Try "*|*:calibration|*:adc|*" or "*|*:calibration|*:adc[*]"
3. Set logiclock region with absolute name, and fix the name whenever you re-ran platform designer.
Let me know whether it helps.
Richard Tan
- RichardT_altera4 years ago
