MarkSlovick
4 years agoLicense Server Issue
We have installed the license server to accommodate our floating license, but mgcld will not start and there is no apparent reason why. Below is the output from LMTOOLS and lmgrd.
The following is...
MarkSlovick
4 years agoI reviewed the video when initially setting up the license server and again today. There is no information for troubleshooting this issue.
The license file specifies the following:
VENDOR mgcld C:\intelFPGA_pro\21.4\ip\altera\mentor_vip_ae\common\win64\mgls\lib port=1802
The debug log contains the following:
10:26:42 (lmgrd) CreateProcess error code: 0x5 File= C:\intelFPGA_pro\21.4\ip\altera\mentor_vip_ae\common\win64\mgls\lib
10:26:42 (alterad) FlexNet Licensing version v11.18.2.0 build 281478 x64_n6
10:26:42 (lmgrd) License server manager (lmgrd) startup failed:
10:26:42 (lmgrd) File not found, mgcld.exe
In this screenshot you can see that the mgcld path is correct.
Do you have any recommendations for what I should try next?
