MarkSlovick
4 years agoLicense Server Issue
We have installed the license server to accommodate our floating license, but mgcld will not start and there is no apparent reason why. Below is the output from LMTOOLS and lmgrd.
The following is...
AR_A_Intel
4 years agoHi
As I understand, the error causes:
· Wrong/Corrupted license file.
· The mgcld service is pointing to wrong location (either the license file or the debug.log is in a different directory).
The most commonly caused is the ports are being used or a VPN/Firewall setting stopping the connection.
If you have a Firewall or have other License servers running on the same machine you may need to change the Server Ports.
