13 years ago
internal latches are permanently disabled.
i am having a problem regarding internal latches.
i have joined two blocks using a block diagram file.
when i compile the whole .bdf file it compiles successfully. bt it shows warning that internal latches of 2nd blocks are permanently disabled.
when i compile .vhd file of 2nd block separately then also it shows the same warnings.
so i am not able to see those latches in my vector waveform file.
what may be the problem??
please reply fast if any one knows the solution..
thank you.
