IESG2000
4 years agoInternal fatal error when I try to compile and starting analys and synthesis
Hello.
I tried to compile simple programming in VHDL for comparison at inputs using logic gates. When the compilation is working, pops up a window to inform me about an internal error, it happens...
SyafieqS
4 years agoGalvan,
Glad you able to resolve it.
May I know if you able to share the qar design file or zip files for me to reproduce the issue.
This issue will be filed as KDB.
Appreciate you effort, thanks
