IESG2000
4 years agoInternal fatal error when I try to compile and starting analys and synthesis
Hello.
I tried to compile simple programming in VHDL for comparison at inputs using logic gates. When the compilation is working, pops up a window to inform me about an internal error, it happens...
SyafieqS
4 years agoGalvan,
Is this issue intermittently occur?
What device you are using? Can you migrate to the latest Quartus for supported device? as it has more bug fixed and updates.
Is reinstall the Quartus fix your issue?
Another way is to follow as what other user faced in below forum link
IESG2000
4 years agoHello.
I reinstalled Quartus II 3 times; it again popped up with fatal errors. I used an old FPGA; Altera DE2 board Cyclone II EP2C35F672C6; i.e. the reason I use Quartus II v13 is that it is the oldest version of the software available to download from the intel website, and it can support the mentioned board. Hence, I gonna see the direction suggested by you.
I appreciate your attention. Blessings!
