18 years agoInternal Error: Sub-system: TDC, File: /quartus/tsm/tdc/tdc_accessories_analysis.cpp,
Hi All:
We are getting the following error when targeting a Cyclone III device: Internal Error: Sub-system: TDC, File: /quartus/tsm/tdc/tdc_accessories_analysis.cpp, Line: 1571 m_edge_domain_data[iedge].m_relaxed_domain_slack_ratio < JUST_BELOW_HUGE_FLOAT Stack Trace: 0x59E2 : _Dinkum_std::hash_compare<TDC_PATH_TIMING *,_Dinkum_std::less<TDC_PATH_TIMING *> >::operator() + 0x3B62 (TSM_TDC) End-trace Quartus II Version 7.2 Build 203 02/05/2008 SJ Full Version Service Pack Installed: 2 Or Internal Error: Sub-system: FITCC, File: /quartus/fitter/fitcc/fitcc_tdc_utility.cpp, Line: 1286 edge_slack_ratio >= 0.0 Stack Trace: 0x76027 : FITCC_TDC_UTILITY::get_slack_ratio_of_connection + 0x177 (FITTER_FITCC) 0x1324C8 : FSYN_EXPERT::tune_stability_threshold + 0x44F78 (fitter_fsyn) End-trace Quartus II Version 7.2 Build 175 11/20/2007 SJ Full Version Service Pack Installed: 1 However the same code works under Stratix II and worked under Cyclone III until resently (minor code changes). We have a service request in, but has anyone else seen these issues.. (As you can see we are on 7.2 either SP1 or SP2. Pete
