16 years agoThe second case is known. You can't program a SOF into the FPGA while the blaster is in use.
The first case is new to me. Usually the nios2-download app detects that the programmer is using the cable and waits until the programmer is finished then downloads the elf file and launches the console. Never had an issue here. Jake
