Intel quartus: generate_from_tcl
Facing a below error while using generating from tcl file in Ubuntu 20.04. Following rocketboards.org website to make FPGA flasher files,
https://rocketboards.org/foswiki/Projects/AgilexSoCSingleQSPIFlashBoot
$ make generate_from_tcl
2021.12.08.00:16:22 Info: Synchronizing System Information for periph_clk
2021.12.08.00:16:22 Info: Synchronizing System Information for periph_rst_in
make[1]: *** [Makefile:644: qsys_generate_qsys] Error 1
make[1]: Leaving directory '/home/xxxxxxx/bkp/agilex_gsrd/agilex_soc_devkit_ghrd'
make: *** [Makefile:657: generate_from_tcl] Error 2
Getting error in the below section,
Length of argument: 1
connect To:[periph.button_pio_irq]
2021.12.08.00:16:06 Info: add_connection agilex_hps.f2h_irq0 periph.button_pio_irq
2021.12.08.00:16:06 Error: add_connection agilex_hps.f2h_irq0 periph.button_pio_irq: No interface named agilex_hps.f2h_irq0.
connect To:[periph.dipsw_pio_irq]
2021.12.08.00:16:06 Info: add_connection agilex_hps.f2h_irq0 periph.dipsw_pio_irq
2021.12.08.00:16:06 Error: add_connection agilex_hps.f2h_irq0 periph.dipsw_pio_irq: No interface named agilex_hps.f2h_irq0.
2021.12.08.00:16:06 Info: set_connection_parameter_value agilex_hps.f2h_irq0/periph.button_pio_irq irqNumber 1
2021.12.08.00:16:06 Error: set_connection_parameter_value agilex_hps.f2h_irq0/periph.button_pio_irq irqNumber 1: No interface named agilex_hps.f2h_irq0.
2021.12.08.00:16:06 Info: set_connection_parameter_value agilex_hps.f2h_irq0/periph.dipsw_pio_irq irqNumber 0
2021.12.08.00:16:06 Error: set_connection_parameter_value agilex_hps.f2h_irq0/periph.dipsw_pio_irq irqNumber 0: No interface named agilex_hps.f2h_irq0.
2021.12.08.00:16:06 Info: add_connection periph.ILC_irq periph.button_pio_irq
- EBERLAZARE_I_Intel
Are you using the GHRD design? If so, did you made any further changes from the GHRD?
Can you check if your Quartus License is valid?
- rajasekarselva
Thanks for your reply. Problem with the license file(.dat). Once we updated with the valid one, it is making the output files without issues.
Thanks for the update, glad it is working for you now.
