Intel PCIe Hard IP Trouble With EFI
- 4 years ago
Avalon busing appears broken, then you can use the linux 'lspci -vvv' command to verify if the host has correctly set the PCIe endpoint Control register.
As example below, the software driver at host side should set the Memory Space Enable bit[1] and Bus Master bit[2] in Command register to 1.
bit[1] Memory_Space_enable must set (Mem+)
bit[2] Bus_Master must set (BusMater+)
- MZora4 years ago
Yes, it appears that the registers are slightly different when linux hands over the device to my pci driver between the EFI and conventional BIOS bases.
diff efi.txt bios.txt
< Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
> Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
3a4
> Latency: 0, Cache Line Size: 64 bytesI attached the full lspci -vvv -d 1234:0000 dump for both cases.
As you point out the BusMaster flag is not set with EFI booting and also a setting related to caching is not set with EFI.
This is after my linux driver loads, which like I said is failing very badly in the EFI case. I know this isn't a linux driver community and I can take my grips over to the linux e-mail lists, but I don't understand why my driver needs to work differently between BIOS and EFI. Or why bus mastering needs to be turned on even through my design uses no bus mastering.
I'm a bit concerned about the caching flag difference as well.
- MZora4 years ago
I manually fixed the settings in my pci driver and all in well now.
