Integer is not the only one solution. You can use unsigned type. Here is your code modified. Note that you have to include the ieee.numeric_std library to use unsigned.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity CounTest is
port (
in_load : in std_logic;
in_data : in std_logic_vector(4 downto 0);
in_clock : in std_logic;
in_ena : in std_logic;
out_count : out std_logic_vector(4 downto 0)
end CounTest;
architecture Behavior of CounTest is
signal reg : unsigned(4 downto 0);
begin
process(in_load, in_clock, in_ena)
begin
if (rising_edge(in_clock)) then
if (in_load = '1') then
reg <= unsigned(in_data);
elsif (in_ena = '1') then
reg <= reg + 1;
end if;
end if;
out_count <= std_logic_vector(reg);
end process;
end Behavior;
An additionnal remark also, you don't need to put in_load and in_ena in the sensitivity list of the process, since the output is modified only on rising edge of the clock.
