In the file (second part), you have the following instantiation :
i1 : CounTest
PORT MAP (
-- list connections between master ports and signals
in_clock => in_clock,
in_data => in_data,
in_ena => in_ena,
in_load => in_load,
out_count => out_count
and just above the declaration of the signals
SIGNAL in_clock : STD_LOGIC;
SIGNAL in_data : STD_LOGIC_VECTOR(4 DOWNTO 0);
SIGNAL in_ena : STD_LOGIC;
SIGNAL in_load : STD_LOGIC;
SIGNAL out_count : STD_LOGIC_VECTOR(4 DOWNTO 0);
You can see that in_data and out_count are defined as std_logic_vector and not integer as you did in your entity, this is why ModelSim gives you the error.
I have never used the Quartus Simulator, but can you explicitely tell it to use integer and not std_logic_vector ?
