12 years agoYes it is automatic. When you generate your system in SOPC builder, it creates or updates the .sopcinfo file that describes the vectors. Then Nios EDS uses that file to make the link script with all the memory sections.
You should try and find out why you don't have the code at the reset address. It could be an option somewhere in the bsp settings.
