Thanks Kaz…
I have 3 signal clock form a PLL, whose goes to a mux of 3.
I need that the skew of this signal be 0.
So when I implement the system with out SP (with out SP is the real system) I simulate it and I can calibrate the phase shift of the 3 signal with the PLL, hence, I can compensate the different delay of the mux, hence I can “set” the skew to 0.
So when I’ll test all system in the chip I need use a SP block, because I have 10 binary inputs and I haven’t 10 switches on the board. Using the SP block the fitter change all, hence, the initial calibration on the PLL is useless.
Kaz, can you explain the question please? Because I don’t understand
“Are you getting reported skew?”
My English is not good, so I hope you understand.
So thanks for all.
Ignacio.
