HPS unused IO Access on Arria 10
- 4 years ago
I understand now, however in your case, in the documentation stated that:
There are 48 HPS peripheral pins that are shared with the FPGA core. They are divided into four quadrants of 12 signals per quadrant. Each quadrant can be assigned to the HPS or the FPGA fabric.
In each shared I/O quadrant, all 12 I/Os are assigned either to the FPGA or to the HPS. It is not possible to divide the I/Os in a quadrant between the FPGA and HPS.
So if you must, you have to have all the HPS' 12 I/Os on one quadrant in order to use the maximum 3 quadrant for FPGA.
Reference:
https://www.intel.com/content/www/us/en/docs/programmable/683711/21-2/shared-i-o-pins.html
Any update from your side?
The settings are in the Advanced Pin Placement tabs, in the HPS parameters in the screenshot if you can see. Open that, and set to the GPIO "pin name".
- BTanner4 years ago
I believe, and it matches with the behavior of Quartus’ Interface Planner, that to assign unused HPS GPIO, from the 2L bank, for connection to the fabric (not HPS) you add the GPIO Intel FPGA IP (they no longer use the term Loaner I/O).
This will provide an I/O connection to the I/O pad and an interface for the FPGA Fabric.
The Interface Planner will allow placement of the pad_in/out only in the Q3 & Q4 I/Os of the 2L bank. It is supposed to allow placement of them in the unused pins of the Q1 & Q2 pins.
The selection of the GPIO in the IP selection on the Advanced Pin Placement, assigns an IO pin to the HPS and not a connection to the fabric.
