HPS unused IO Access on Arria 10
- 4 years ago
I understand now, however in your case, in the documentation stated that:
There are 48 HPS peripheral pins that are shared with the FPGA core. They are divided into four quadrants of 12 signals per quadrant. Each quadrant can be assigned to the HPS or the FPGA fabric.
In each shared I/O quadrant, all 12 I/Os are assigned either to the FPGA or to the HPS. It is not possible to divide the I/Os in a quadrant between the FPGA and HPS.
So if you must, you have to have all the HPS' 12 I/Os on one quadrant in order to use the maximum 3 quadrant for FPGA.
Reference:
https://www.intel.com/content/www/us/en/docs/programmable/683711/21-2/shared-i-o-pins.html
Thanks for that input. I understand about the fixe placement of the HPS peripherals. It is the unused ones, that are free to connect to the FPGA fabric. It is these unused ones where the Interface Planner only allows the placement of these in the GPIO1 pins of the 2L bank and not the GPIO0. The unused (by the HPS) pins of the entire 2L bank are supposed to be assignable to the fpga fabric.
